Текущее время: 15 ноя 2026, 08:07
 Заголовок сообщения: сервисные опции шаси MC-59C
СообщениеДобавлено: 03 сен 2013, 08:34
шасси MC-59C
процессор EAN36193601 LG048N 9R 58R5 8EA52
вход в сервис- одновременное нажатие на "MENU" с пульта и клавиатуры
Пульт-или родной или 124D
опции списаны с модели LG 21FU1RG
VP 0 RF AGC 54
VP 1 VS 4
VP 2 VL 15
VP 3 VA 42
VP 4 HS 11
VP 5 EW 50
VP 6 EP 27
VP 7 ET 27
VP 8 EW UPCOR 15
VP 9 EW LOCOR 7
VP 10 SC 17
VP 11 V COMP 6
VP 12 H COMP 0
VP 13 VDC 25
VP 14 VBLK S 14
VP 15 H BLK L 7
VP 16 H BLK R 3
VP 17 EW-CSW 1
VP 18 R BIAS 121
VP 19 G BIAS 127
VP 20 B BIAS 117
VP 21 R DRIVE 8
VP 22 G DRIVE 8
VP 23 B DRIVE 58
VP 24 AFC GAIN 0
VP 25 H FREQ 16
VP 26 CD MODE 7
VP 27 FBP SW 1
VP 28 YC FILTER 2
VP 29 Y ARF 0
VP 30 C SYSTEM 0
VP 31 C VCO 4
VP 32 PAL APC 0
VP 33 S TRAMP SW 0
VP 34 VIF SYS 1
VP 35 VCO FREQ 112
VP 36 SIF SYS 1
VP 37 SVB BIAS 45
VP 38 BRIGHT 64
VP 39 ABL 0
VP 40 BRI STOP 0
VP 41 ABL TH 4
VP 42 RGB TEMP 1
VP 43 COR GAIN 3
VP 44 PRE SHOT 2
VP 45 OVER SHOOT 2
VP 46 Y GAMMA 0
VP 47 DC REST 1
VP 48 B-S START 1
VP 49 B- ST GAIN 1
VP 50 C BYPASS 1
VP 51 C KILL ON 0
VP 52 C KILL OFF 0
VP 53 C KILL OPER 7
VP 54 RB BAL 10
VP 55 RB ANG 8
VP 56 B-Y LEVEL 28
VP 57 R-Y LEVEL 27
VP 58 V LEVEL 7
VP 59 OVER MO SW 0
VP 60 OVER MO LE 8
VP 61 TINT TH 0
VP 62 Y TH 1
VP 63 Y GAIN 1
VP 64 R WIDTH 0
VP 65 R OFF SET 0
VP 66 B WIDTH 0
VP 67 B OFF SET 0
VP 68 T DISABLE 1
VP 69 V TRANCE 0
VP 70 A MUTE 0
VP 71 V MUTE 0
VP 72 SNC KILL 0
VP 73 V KILL 0
VP 74 FSC SW 0
VP 75 GRAY 0
VP 76 CROSS BW 0
VP 77 RGB BLK 0
VP 78 C EXT 0
VP 79 CBCR IN 0
VP 80 AUDIO SW 0
VP 81 VOL FIL 0
VP 82 WPL OPE 1
VP 83 SYNC SS 2
VP 84 FM MUTE 0
VP 85 IF AGC 0
VP 86 A-OUT SW 1
VP 87 DE-EMPH 0
VP 88 FM GAIN 1
VP 89 VOLUME 126
VP 90 HL LDET 1
VP 91 GY AMP 4
VP 92 S TRAMP 4
VP 93 C TRAMP 7
VP 94 VL OFFS 3
VP 95 A2 SW 0
VP 96 FLESH 0
VP 97 ERGB CONT 8
VP 98 PIQ OSD 0
VP 99 VM AUD SW 0
VP 100 VIN RGBSW 1
VP 101 THNO C 0
VP 102 APC OFF 4
VP 103 EQU AD 8
VP 104 BEL AD 3
VP 105 EQU ON 0
VP 106 BA SW 0
VP 107 SECKOFF 0
VP 108 SECK ON 0
VP 109 OSD CONT 5
VP 110 OSD POS 38
 Заголовок сообщения: Re: сервисные опции шаси MC-59C
далее: при нажатии на кнопку "MENU"
попадаем в дополнительные подпункты
DVD 1
TURBO ME 1
V CURVE 1
V MUTE 1
EYE 0
FLAT 0
SND MUTE 1
GAME 0
TURBO 1
ARC 0
200PR 0
BLUE BACK 0
TORBO AT 1
SHARP 1
DVDN 6P 0
SLIM 0
FM TRAN 0
NTSC 1
AV PREV 1
SYNC KI 1
A2SW 0
LNA 0
S WOOFER 0
PS2NCLR 0
SYSTEM 0 CIS
SND MODE 1 AV ST
AV 1 AV 1
LOC KEY 1 6KEY
COLOR TT 1
PLL DIV 31
FM PRE 6
NICAM PRE 7
SCART PRE 0
A2FM TH 5
FIRST TH 10
ZWT THRE 12
