| сервисные опции шаси MC-59C http://radio-uchebnik.ru/forum/viewtopic.php?f=26&t=14 |
Страница 1 из 1 |
| Автор: | Evgeniy811 [ 03 сен 2013, 08:34 ] |
| Заголовок сообщения: | сервисные опции шаси MC-59C |
шасси MC-59C процессор EAN36193601 LG048N 9R 58R5 8EA52 вход в сервис- одновременное нажатие на "MENU" с пульта и клавиатуры Пульт-или родной или 124D опции списаны с модели LG 21FU1RG VP 0 RF AGC 54 VP 1 VS 4 VP 2 VL 15 VP 3 VA 42 VP 4 HS 11 VP 5 EW 50 VP 6 EP 27 VP 7 ET 27 VP 8 EW UPCOR 15 VP 9 EW LOCOR 7 VP 10 SC 17 VP 11 V COMP 6 VP 12 H COMP 0 VP 13 VDC 25 VP 14 VBLK S 14 VP 15 H BLK L 7 VP 16 H BLK R 3 VP 17 EW-CSW 1 VP 18 R BIAS 121 VP 19 G BIAS 127 VP 20 B BIAS 117 VP 21 R DRIVE 8 VP 22 G DRIVE 8 VP 23 B DRIVE 58 VP 24 AFC GAIN 0 VP 25 H FREQ 16 VP 26 CD MODE 7 VP 27 FBP SW 1 VP 28 YC FILTER 2 VP 29 Y ARF 0 VP 30 C SYSTEM 0 VP 31 C VCO 4 VP 32 PAL APC 0 VP 33 S TRAMP SW 0 VP 34 VIF SYS 1 VP 35 VCO FREQ 112 VP 36 SIF SYS 1 VP 37 SVB BIAS 45 VP 38 BRIGHT 64 VP 39 ABL 0 VP 40 BRI STOP 0 VP 41 ABL TH 4 VP 42 RGB TEMP 1 VP 43 COR GAIN 3 VP 44 PRE SHOT 2 VP 45 OVER SHOOT 2 VP 46 Y GAMMA 0 VP 47 DC REST 1 VP 48 B-S START 1 VP 49 B- ST GAIN 1 VP 50 C BYPASS 1 VP 51 C KILL ON 0 VP 52 C KILL OFF 0 VP 53 C KILL OPER 7 VP 54 RB BAL 10 VP 55 RB ANG 8 VP 56 B-Y LEVEL 28 VP 57 R-Y LEVEL 27 VP 58 V LEVEL 7 VP 59 OVER MO SW 0 VP 60 OVER MO LE 8 VP 61 TINT TH 0 VP 62 Y TH 1 VP 63 Y GAIN 1 VP 64 R WIDTH 0 VP 65 R OFF SET 0 VP 66 B WIDTH 0 VP 67 B OFF SET 0 VP 68 T DISABLE 1 VP 69 V TRANCE 0 VP 70 A MUTE 0 VP 71 V MUTE 0 VP 72 SNC KILL 0 VP 73 V KILL 0 VP 74 FSC SW 0 VP 75 GRAY 0 VP 76 CROSS BW 0 VP 77 RGB BLK 0 VP 78 C EXT 0 VP 79 CBCR IN 0 VP 80 AUDIO SW 0 VP 81 VOL FIL 0 VP 82 WPL OPE 1 VP 83 SYNC SS 2 VP 84 FM MUTE 0 VP 85 IF AGC 0 VP 86 A-OUT SW 1 VP 87 DE-EMPH 0 VP 88 FM GAIN 1 VP 89 VOLUME 126 VP 90 HL LDET 1 VP 91 GY AMP 4 VP 92 S TRAMP 4 VP 93 C TRAMP 7 VP 94 VL OFFS 3 VP 95 A2 SW 0 VP 96 FLESH 0 VP 97 ERGB CONT 8 VP 98 PIQ OSD 0 VP 99 VM AUD SW 0 VP 100 VIN RGBSW 1 VP 101 THNO C 0 VP 102 APC OFF 4 VP 103 EQU AD 8 VP 104 BEL AD 3 VP 105 EQU ON 0 VP 106 BA SW 0 VP 107 SECKOFF 0 VP 108 SECK ON 0 VP 109 OSD CONT 5 VP 110 OSD POS 38 |
| Заголовок сообщения: | Re: сервисные опции шаси MC-59C |
далее: при нажатии на кнопку "MENU" попадаем в дополнительные подпункты DVD 1 TURBO ME 1 V CURVE 1 V MUTE 1 EYE 0 FLAT 0 SND MUTE 1 GAME 0 TURBO 1 ARC 0 200PR 0 BLUE BACK 0 TORBO AT 1 SHARP 1 DVDN 6P 0 SLIM 0 FM TRAN 0 NTSC 1 AV PREV 1 SYNC KI 1 A2SW 0 LNA 0 S WOOFER 0 PS2NCLR 0 SYSTEM 0 CIS SND MODE 1 AV ST AV 1 AV 1 LOC KEY 1 6KEY COLOR TT 1 PLL DIV 31 FM PRE 6 NICAM PRE 7 SCART PRE 0 A2FM TH 5 FIRST TH 10 ZWT THRE 12 |
